Comware
HP 1920 48p firmware update
This thread has been viewed 16 times
  • 1.  HP 1920 48p firmware update
    Posted Jan 11, 2021 07:27 AM
    Hello all, I am new in HP technology. By mistake I have delete everything of my HP 1920 switch. Now, how can I push new firmware to my switch to run. thank you for your advice.
  • 2.  RE: HP 1920 48p firmware update
    Posted Jan 11, 2021 07:54 AM
    Hello Rashed,
    If your device is 1920 (not 1920s)  you can use the following link to download the firmware please check which is your model before downloading and usnig the firmware:
    HPE 1920 48G Switch (JG927A):
    https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=JG927A
    HPE 1920 48G PoE+ (370W) Switch (JG928A):
    https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=JG928A
    Then you can use the procedure in the release notes from the following link on page 30 (Upgrading from the BootWare menu):
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00069833en_us
    Hope this helps!
  • 3.  RE: HP 1920 48p firmware update
    Posted Jan 11, 2021 09:38 AM
    Thank you so much Alex. I will follow your instruction. If I found some difficulties then will msg here.
  • 4.  RE: HP 1920 48p firmware update
    Posted Jan 11, 2021 11:26 AM
    Hello Alex. Thank you so much. I have got access on the switch. Now I am facing another issue. May be it simple but I said I am new in HP tech. After updating I can't get switch menu that I can configure. I mean it doesn't show on cli (switch>) like this. it shows <HPE> and it doesn't recognise regular command. Thank you for your time and advice.
  • 5.  RE: HP 1920 48p firmware update
    Posted Jan 13, 2021 08:38 AM
    Hello Rashed,
    Please check the user guide for this switch:
     HPE OfficeConnect 1920 Switch Series User Guide
    Hope this helps!
  • 6.  RE: HP 1920 48p firmware update
    Posted Apr 16, 2024 09:22 AM
    Hi
    I know its 3years later, but i have same problem. But if i trying to open that link it opens dashboard. How can i get firmware?
