Comware
HP 1920 divided into two switches
  • 1.  HP 1920 divided into two switches
    Posted 19 days ago
    There is an HP 1920 switch with 24 ports, and it needs to be divided into two separate virtual switches. For example, port 1-8 is vlan 1, and port 9-24 is vlan 21. Both Vlans must use the same subnet, for example 10.0.0.1/24. Gateway 10.0.0.1 is plugged into port 1, computer 10.0.0.21 is plugged into port 21. Access of computer 10.0.0.21 to gateway 10.0.0.1 should appear only if both vlan-based virtual switches are connected via port 8 - 9.
    vlan 1
    vlan 21
     description VLAN 0021 test
    interface GigabitEthernet1/0/1 - 7
     port auto-power-down
     stp edged-port enable
    interface GigabitEthernet1/0/8
     port link-type hybrid
     port hybrid vlan 1 21 tagged
    interface GigabitEthernet1/0/9
    interface GigabitEthernet1/0/10 - 24
     port access vlan 21
