I'm using the switch belong and I'm running PD.02.06 firmware, which is the newest. Here is my switch config:
!Current Configuration:
!System Description "HPE OfficeConnect Switch 1920S 48G 4SFP JL382A, PD.02.06, Linux 3.6.5-a07f8920, U-Boot 2012.10-00118-g3773021 (Oct 11 2016 - 15:39:54)"
!System Software Version "PD.02.06"
!System Up Time "0 days 2 hrs 55 mins 11 secs"
!Additional Packages HPE QOS,HPE IPv6 Management,HPE Routing
!Current SNTP Synchronized Time: Oct 17 13:20:38 2018 UTC
network protocol none
network parms 172.24.1.11 255.255.255.0 172.24.1.254
vlan database
vlan 2-5,42-43,126
vlan name 2 "VoIP"
vlan name 3 "Lab"
exit
ip http secure-server
ip http secure-protocol TLS1
ip ssh server enable
ip ssh protocol 2
configure
sntp client mode unicast
sntp server "192.168.100.254"
sntp server "192.168.100.38"
sntp server "192.168.100.39"
clock summer-time recurring EU offset 60
time-range Schedule-1
exit
time-range Schedule-2
exit
username "admin" password XXX level 15 encrypted
no username guest
dot1x system-auth-control monitor
aaa authentication dot1x default radius
authorization network radius
dot1x dynamic-vlan enable
voice vlan
radius accounting mode
radius server host auth "172.24.43.43" name "freeradius-virt"
radius server key auth "172.24.43.43" encrypted XXX
radius server primary "172.24.43.43"
radius server attribute 4 172.24.1.11
radius server host acct "172.24.43.43" name radius-virt
radius server key acct "172.24.43.43" encrypted XXX
radius server host acct "172.24.2.144" name freeradius-virt-2
radius server key acct "172.24.2.144" encrypted XXX
line console
exit
line telnet
exit
line ssh
exit
port-channel linktrap TRK 1
port-channel linktrap TRK 2
snmp-server sysname "here"
snmp-server location "Redroom"
snmp-server contact "me@mail.tld"
port-security
interface 1
mtu 9000
vlan participation exclude 3-4
vlan participation include 2,43
vlan tagging 2,43
exit
interface 2
voice vlan 2
dot1x pae supplicant
mtu 9000
vlan acceptframe admituntaggedonly
vlan tagging 2,43
exit
According to the documentation I have to enable the Administrative Mode.
First I tried it in the GUI: Enable it, clicking on save and then on apply. Each time, when I click on "apply" the ssh server and also the webserver get a timeout. The only way to restart the switch is to pull the power cable. After I'm online again and logged in, I notice, that the Administrative Mode is disabled. When I don't use "save config" and I just use "apply" it also freezes. That's the reason why I tried to configure the switch via SSH:
(HPE Routing) (Config)#show dot1x
Administrative Mode............... Disabled
VLAN Assignment Mode.............. Enabled
Dynamic VLAN Creation Mode........ Enabled
Monitor Mode...................... Enabled
EAPOL Flood Mode.................. Disabled
(HPE Routing) (Config)#dot1x ?
dynamic-vlan Configure dot1x dynamic vlan creation parameters.
eapolflood Enable/Disable EAPOL flood support on the switch.
port-control Set the authentication mode on the specified port.
system-auth-control Enable/Disable authentication support on the
switch.
user Add/Remove user from the list with access to the
specified port.
I'm missing a way to enable the Administrative Mode with dot1x.
Can you give me an advise?
Thx
#jl382a#1920S#802.1x
