Comware
HP 1950
  • 1.  HP 1950
    Posted Jul 05, 2022 03:11 PM
    Hi I has having a stack of two HP 1950 switches, because of power failure the switch is not operational and when i try to login using console I am getting the below options only. I tried upgrade firmware using boot + b and TFTP but even after upgrade the options are same and are limited. I can't do any thing.
    Kindly assist.
  • 2.  RE: HP 1950
    Posted Jul 06, 2022 03:40 AM
    Hello lovalim,
    This is the default basic CLi mode of the 1950 as outlined in the user guide starting page 138:
    Commands are available for you to perform basic device management when the Web interface is not
    available.
    To manage the device from the CLI, access the device through the console port or Telnet. You are
    placed in user view immediately after you log in to the CLI.
    Table 22 provides a command summary. All these commands are available in user view. However,
    the commands you can use depend on the user roles you have. By default, a command is available
    for the predefined user roles. You can use the RBAC feature to assign a command to additional user
    roles from the Web interface.
    https://www.hpe.com/psnow/doc/c04657809
    Hope this helps!
    -Alex-
