Wired Intelligent Edge
  • 1.  HP 1950 and Procurve 5406zl
    Posted Aug 02, 2019 04:04 AM
    Good afternoon, colleagues!
    I have a small part of the network that operates HP 1950- cisco 2960-hp procure 5406zl.
    ports have the following settings:
    hp 1950
    interface GigabitEthernet1 / 0/3
     port link-type trunk
     port trunk permit vlan all
    cisco 2960
    interface GigabitEthernet1 / 0/5
     switchport trunk encapsulation dot1q
     switchport mode trunk
     no ip address
     no mdix auto
    hp procurver 5406
    port A3
    vlan1 untagged
    the rest of vlan taged
    I want to exclude cisco 2960 from this chain. On hp 1950 I leave the same port settings
    I need a new port on HP procurve. I made it trk1, indicated vlan1 untagged, the rest vlan tagged. For some reason, this configuration does not work, everything is vlan, except vlan1 do not see hp 1950 and the server behind it. Please tell me what I did wrong. Thank you in advance!
    #5406zl
    #hp19505406zl
    #hp1950
  • 2.  RE: HP 1950 and Procurve 5406zl
    Posted Aug 02, 2019 05:08 AM
    Did you configure the "switchport trunk native vlan" for the untagged VLAN and permit the tagged VLANs across the links on Cisco with "switchport trunk allowed vlan x" ? It looks like it's missing in the configuration you've posted.
  • 3.  RE: HP 1950 and Procurve 5406zl
    Posted Aug 02, 2019 05:31 AM
    @komarovaa wrote: I need a new port on HP procurve. I made it trk1, indicated vlan1 untagged, the rest vlan tagged. For some reason, this configuration does not work, everything is vlan, except vlan1 do not see hp 1950 and the server behind it. Please tell me what I did wrong.
    You're confusing HP ProVision / HPE Aruba ArubaOS-Switch "Trunk" (Aggregation of more physical ports in a logical port called trkX where X is a positive integer number which define the Trunk ID) with "trunk" mode of operation of a port - in HP Comware / Cisco IOS jargon - which permits to carry more tagged VLAN into a physical (or logical) link.
    So HP/Aruba side if you need a single physical port Z to be untagged member of a VLAN X and also tagged member of various other VLAN IDs (typically that port will be used to "trunk" in Cisco jargon various VLANs to downlink/uplink devices...which should be your case here) you just need to type these commands:
    interface ethernet Z untagged vlan X
    interface ethernet Z tagged vlan A,B,C,D-F,G
    Change letters with VLAN IDs you really need (single, multiple, ranges).
    Not sure what you mean with the expression "exclude cisco 2960 from this chain" but if you just need to relocate (topologically speaking) your Cisco 2960 to uplink it directly to your HP 5406zl then you just need to configure a dedicated port (downlink to Cisco 2960) with the same VLAN settings you actually have on the Cisco 2960 port used for actual uplink.
  • 4.  RE: HP 1950 and Procurve 5406zl
    Posted Aug 02, 2019 07:27 AM
    Thank you, I corrected, removed the group mk 1
    I configured port D24 to connect the Procurve 5406 to it. Have I configured it correctly?
    vlan 1
       name "first"
       untagged A1-A24,B1-B24,C1,C4-C21,C23-C24,D1-D24
       ip address 10.16.0.22 255.255.0.0
       tagged C2
       no untagged C3,C22
       exit
    vlan 51
       name "51"
       untagged C3
       tagged A3,D1,D24
       no ip address
       exit
    vlan 52
       name "52"
       tagged A3,C24,D1,D24
       no ip address
       exit
    vlan 100
       name "100"
       tagged A3,D24
       no ip address
       exit
    vlan 53
       name "53"
       tagged A3,C15,D1,D24
       no ip address
       exit
    vlan 99
       name "99"
       ip address 10.1.30.3 255.255.255.0
       tagged A3,C15,D24
       exit
    vlan 110
       name "VLAN110"
       tagged A3,D24
       no ip address
       exit
    vlan 190
       name "190"
       tagged A3,D4,D24
       no ip address
       exit
    vlan 167
       name "167"
       tagged A3,C1,D24
       no ip address
       exit
    vlan 112
       name "112"
       tagged A3,C1,D24
       no ip address
       exit
    vlan 700
       name "K11"
       tagged A3,C1,D1,D24
       no ip address
       exit
    vlan 701
       name "701"
       tagged A3,C1,D1,D24
       no ip address
       exit
    vlan 702
       name "702"
       tagged A3,C1,D1,D24
       no ip address
       exit
  • 5.  RE: HP 1950 and Procurve 5406zl
    Posted Aug 02, 2019 08:12 AM
    I'm lazy today...it's Friday! ...please show us the output of:
    show vlan port D24 detail
     that's useful to see port D24's VLAN tagging status.
  • 6.  RE: HP 1950 and Procurve 5406zl
    Posted Aug 02, 2019 09:06 AM
    Understand. I will decide this question only next weekend, so I decided to ask in advance why it didn’t work for me earlier
      port D24
    VLAN ID Name | Status Voice Jumbo Mode
    1  | Port-based No No Untagged
    25  | Port-based No No Tagged
    30  | Port-based No No Tagged
    34  | Port-based No No Tagged
    40  | Port-based No No Tagged
    51  | Port-based No No Tagged
    52  | Port-based No No Tagged
    53  | Port-based No No Tagged
    99 | Port-based No No Tagged
    100 | Port-based No No Tagged
    110  | Port-based No No Tagged
    111  | Port-based No No Tagged
    112  | Port-based No No Tagged
    150  | Port-based No No Tagged
    167  | Port-based No No Tagged
    190  | Port-based No No Tagged
    700  | Port-based No No Tagged
    701  | Port-based No No Tagged
    702 | Port-based No No Tagged
    703 | Port-based No No Tagged
    704 | Port-based No No Tagged
    705 | Port-based No No Tagged
  • 7.  RE: HP 1950 and Procurve 5406zl
    Posted Aug 02, 2019 09:58 AM
    Not sure to follow you when saying "I decided to ask in advance why it didn’t work for me earlier"...are you saying that it now works but previously not or what else?
    In any case port D24 is untagged member of VLAN id 1 and tagged member of VLAN id 25, 30, 34, 40, 51, 52, 53, 99, 100, 110, 111, 112, 150, 167, 190, 700, 701, 702, 703, 704 and 705...so the only thing you need Cisco side is to setup its uplink interface with something like (if the port will remain the 1/0/5):
    interface GigabitEthernet 1/0/5
    switchport
    switchport trunk native vlan 1
    switchport trunk allowed vlan 1,25,30,34,40,51,52,53,99,100,110,111,112,150,167,190,700,701,702,703,704,705
    switchport nonegotiate
  • 8.  RE: HP 1950 and Procurve 5406zl
    Posted Aug 07, 2019 01:21 AM
    Thank!
    Now works using hp 1950 - cisco 2960 - hp procurve 5406.
    I want to remove the unnecessary transit switch cisco 2960.
    Trunk port is made on HP 1950, it has such settings
    interface GigabitEthernet1 / 0/4
    On HP procurve 5406 I will use port D24, it has such settings (they are also there above)
    vlan 1 untagged
    vlan 2-4096 tagged
    I tried with these settings, but only vlan 1 worked for me.
