I have a HP 1950 JG961A and I have created an ACL (v4) in the GUI but I can't see how you append this ACL to a vLAN ??
Please advise.
Why is it when I ask the question, I then find the answer.
FYI: Under security / Packet Filter / vLAN or Global
How you are creating and applying rule, please explain in brief?
Hopefully you are creating ACL rule under Resources -->ACLs -->IPv4 then applying the rule to vLAN under Security-->Packet Filter-->VLAN-->Applying rule here.
Thanks!
Hello. How many ACL can apply for a vlan in this model. How many rules can create for an ACL. In my scanario, I can assign only single rule(not an acl) for a vlan in HPE 1920s switch. I need to change my existing switch. Please give me your suggestion
