Comware
HP 1950 JG961A IP-HELPER
  • 1.  HP 1950 JG961A IP-HELPER
    Posted Feb 14, 2019 07:00 PM
    i have a  HP 1950 JG961A and i wish to add a DHCP helper to a vlan.  i can't find an option in the GUI and i can find even less in "xtd-cli-mode".
    Infact in xtd, i can display settings but i can't seem to conf t or en .... (i'm no wizard)
    Please advise how i can complete this task.
    #ip-helper
    #DHCP
    #VLAN
  • 2.  RE: HP 1950 JG961A IP-HELPER
    MVP GURU
    Posted Feb 15, 2019 12:52 AM
    I suspect the issue is on terminology used to describe the feature you need...try DHCP Relay Agent (look for HPE OfficeConnect 1950 Switch series User Guide).
  • 3.  RE: HP 1950 JG961A IP-HELPER
    Posted Feb 19, 2019 07:26 PM
    Indeed I found it under DHCP of all places in the GUI, I thought this was DHCP server only, but once enabled i found the relevant settings.
