Wired Intelligent Edge
  • 1.  HP 2530 - Cisco 2960 VLAN problem
    Posted May 09, 2019 11:20 AM
    Hi all, this has been asked numerous times before (by other people) but I'm still having problems!
    I have a HP 2530 connected from port 24 to port 19 on a CISCO 2960 Gigabit Copper
    Using Default VLAN 1 and VLAN 40
    VLAN 40 should get an IP 172.20.x.x
    VLAN 1 IP 172.24.x.x
    Problem
    VLAN 40 traffic not trunking (CISCO trunk not aggregation) from HP 2530 to CISCO 2960
    When a computer is connected to port 20 on the CISCO it gets a VLAN 40 IP address (correct result)
    When a computer is connected to port 5 on the HP it should get a VLAN 40 address but gets a VLAN 1 (incorrect result)
    Set Up
    HP 2530
    Port 5 - VLAN 40 tagged
    Port 5 - VLAN 1 (default native) untagged
    Port 24 - VLAN 40 tagged
    Port 24 - VLAN 1 (default native) untagged
    STP disabled
    CISCO 2960
    Port 19 (Uplink Trunk)
    switchport mode trunk
    switchport nonegotiate
    Port 20
    interface GigabitEthernet0/20
    switchport access vlan 40
    switchport mode access
    spanning-tree portfast trunk (not needed but left)
    STP disabled
    How can I get a computer connected to port 5 on the HP 2530 to pick up a VLAN 40 IP address when passing through the CISCO?
    #cisco
    #2960
    #VLAN
    #2530
  • 2.  RE: HP 2530 - Cisco 2960 VLAN problem
    Posted May 09, 2019 12:01 PM
    Configurar
    HP 2530
    Port 5 - VLAN 40 untagged
  • 3.  RE: HP 2530 - Cisco 2960 VLAN problem
    Posted May 10, 2019 05:33 AM
    Thanks  vladi0782 but I don't think that can be right.
    Surely the port must be tagged VLAN 40 (not untagged) for it to be on the VLAN.
  • 4.  RE: HP 2530 - Cisco 2960 VLAN problem
    Posted May 10, 2019 07:09 AM
    Hi   vladi0782
    Ignore my previous comment, you were correct about the untagging.
    As parnassus has pointed out, your solution was correct when configure with parnassus's help.
    Thanks for this, it has solved a real problem!
  • 5.  RE: HP 2530 - Cisco 2960 VLAN problem
    Posted May 09, 2019 06:56 PM
    Also, port 24 (HP Switch) and port 19 (Cisco Switch) should match their VLANs tagging: this means that, HP side, port 24 should (as is) be untagged member of VLAN 1 and tagged member of VLAN 40...and, Cisco side, port 19 must be native on VLAN 1 and permit VLAN 40.
    In terms of configurations:
    Aruba/HP 2530 (ArubaOS-Switch or HP ProVision):
    vlan 1
    untagged 24
    vlan 40
    tagged 24
    Cisco IOS:
    interface GigabitEthernet 19 <-- eventually correct the interface name
    switchport
    switchport trunk encapsulation dot1q
    switchport trunk native vlan 1
    switchport trunk allowed vlan 1,40 <-- corrected
     See here.
  • 6.  RE: HP 2530 - Cisco 2960 VLAN problem
    Posted May 10, 2019 05:49 AM
    Thanks  parnassus for the information and link.
    I'll try this out later and see if it works.
    One question - on page 4 of the linked pdf has the line
    switchport trunk allowed vlan 1-3
    but in your information you have
    switchport trunk allowed vlan 40
    Do you think I should use:
    or should the native VLAN go through automatically?
  • 7.  RE: HP 2530 - Cisco 2960 VLAN problem
    Posted May 10, 2019 06:25 AM
    Typo, corrected.
    With regards to access port (the port where you're going to connect your client)...if the client isn't able to recognize (or is not setup to recognize) tagged frames...then the switch port should be set as untagged member of VLAN you need to be part of (VLAN 40 in your case)...that's the HP/HPE/Aruba jargon...that's to say that @vladi0782 is correct about that.
    See the example (Access) on the presentation at page 5, on Cisco you have:
    interface GigabitEthernet 0/20
    switchport
    which translates into HP configuration jargon for interface 5:
    vlan 40
    untagged 5
    as @vladi0782 wrote you above.
  • 8.  RE: HP 2530 - Cisco 2960 VLAN problem
    Posted May 10, 2019 07:12 AM
    Thanks, it works!
    Between you and  @vladi0782 the VLAN is now working
    Thanks also for the useful link - it will be added to my massive file of useful information.
  • 9.  RE: HP 2530 - Cisco 2960 VLAN problem
    Posted May 10, 2019 08:44 AM
    Glad we helped and you were able to solve your issue...so we deserve Kudos!
