Wired Intelligent Edge
  • 1.  HP 2530 J9772A Voice VLAN
    Posted Jul 14, 2014 10:51 AM
    Good morning!
    So have two VLANs configured on my switch, the default VLAN for data, and a VLAN2 for voice.  I was troubleshooting the VLAN with a laptop and if I tag a port for VLAN 2, I can get network/internet connectivity on the laptop as long as I enable VLAN and set VLAN 2 on the laptop NIC. If I try to put in a Cisco VoIP (SPA501G) on that port, I don't get any connectivity. Going through the configs, the phone pulls the proper VLAN2 network configurations using IP-Helper, but not VLAN information. I've tried enabling CDP but no luck. Any thoughts would be greatly appreciated.
  • 2.  RE: HP 2530 J9772A Voice VLAN
    Posted Jul 14, 2014 02:36 PM
    Nevermind, problem solved!
  • 3.  RE: HP 2530 J9772A Voice VLAN
    Posted Jul 17, 2014 04:47 AM
    How ?
  • 4.  RE: HP 2530 J9772A Voice VLAN
    Posted Jul 19, 2014 07:05 AM
    Hi, try this:
    qos dscp-map 101110 priority 6
    qos type-of-service diff-services
    vlan 1
       name "DEFAULT_VLAN"
       untagged 1-48,A1-A2,B1-B2
       exit
    vlan 100
       name "VOICE"
       tagged 1-48
       qos dscp 101110
       voice
       exit
    Also enable lldp-med run
    perhaps this helps you ...
    http://www.snackarelli.com/2014/01/procurve-voip-lldp-med-and-qos.html
    #Voice
    #tagged
    #LLDP
    #VLAN
  • 5.  RE: HP 2530 J9772A Voice VLAN
    Posted Jul 19, 2014 07:07 AM
    Why don't you mark your thread as solved and provide a solution ? So you can contribute sth to the forum instead of just asking stuff ?
    Cheers, Chris
  • 6.  RE: HP 2530 J9772A Voice VLAN
    Posted Mar 28, 2017 09:46 AM
    Hi all,
    I have hp 2530 that I want to configure it to use IP phone and Wifi ,its currently a flat switch.
    Please help, I not clued up HP's
  • 7.  RE: HP 2530 J9772A Voice VLAN
    Posted Mar 28, 2017 01:12 PM
    Hi norma,
    Can you please provide a little more Info pls?
