We bought HP 3044 router and HP x60 4GB DDR3 SDRAM UDIMM Memory
And I installed this RAM, but when I use display command to dislay the RAM amount it displays 2GB RAM only not 6 GB
I think the command was display memory
So, is there anything else should I do except installing the RAM into a DIMM ?
I installed the RAM into the first slot one time and into the second slot other time, but same result
#DIMM
