Dear all,
I have a problem with local authentication on my HP 5120SI switches. everything works well, when i use password authentication for console and telnet login, but if i configure local users and apply scheme authentication for vty access, authentication fails. I try telnet access and username/password pair fails. Of course Web access doesn't work.
Has anyone got the same situation ? Any solution?
Config ttached.
#login#comware#5120SI#authentication
