  • 1.  HP 525 and MSM720
    Posted Nov 12, 2015 04:47 AM
    There are devices: MSM720 Controller firmware 6.6.2.0-22792 and connect to the access point HP 525.
    This controller is already working successfully with two access points HP 410 (WLAN, a network created), but now the problem is still connected and HP 525.
    In the admin panel I do not see the access point. It is possible to connect manually? How to do it? Or, the device AP 525 is not compatible with the MSM720 controller, and only works autonomously without a controller?
    #720
    #msm
    #525
  • 2.  RE: HP 525 and MSM720
    Posted Nov 16, 2015 03:54 AM
    Sadly, those aren't compatible..
    Support Matrix: http://h20195.www2.hp.com/V2/GetPDF.aspx%2F4AA5-0345ENW.pdf
