Comware
last person joined: 2 hours ago
Hp 5500 Dhcp by Port?
  • 1.  Hp 5500 Dhcp by Port?
    Posted Nov 26, 2018 01:48 PM
    hello word!
    i need to configure device that requerd dhcp, but in my case i need that if some device connect to port it always taking that ip addres that i config
    example:
    in port 1/0/1-  that ip will be 192.168.1.1
    in port 1/0/2-  that ip will be 192.168.1.2
    (dhcp static in not a reallty option)  , i usead Hp 5500 comware 7
    thanks for help (:
    #DHCP
  • 2.  RE: Hp 5500 Dhcp by Port?
    MVP GURU
    Posted Nov 26, 2018 05:13 PM
    Since (MAC Address) DHCP Static Binding is out of question...a way to apply a dynamic (but which doesn't change over time) IP Address allocation on a Interface is to do a trick: probably two different IP Pools (each one with just one IP Address, respectively, 192.168.1.1 and 192.168.1.2 referenced by two differents DHCP IP Pools) assigned, each one, to required interface.
    interface 1/0/1
    dhcp server apply ip-pool pool-for-1-0-1
    interface 1/0/2
    dhcp server apply ip-pool pool-for-1-0-2
    where pool-for-1-0-1 and pool-for-1-0-2 have two differents one-IP-Address addresses ranges (if possible):
    pool-for-1-0-1: address range 192.168.1.1 192.168.1.1
    pool-for-1-0-2: address range 192.168.1.2 192.168.1.2
    That's teorethical...to be verified.
