can anyone help?
I need to create a sub interface on HP 5820. However, it seems it´s not possible to create this interface:
HP Comware Platform Software
Comware Software, Version 5.20.105, Release 1808P12
HP A5820AF-24XG Switch with 2 Processors
1024M bytes SDRAM
4M bytes Nor Flash Memory
512M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is Ver.B
CPLDA Version is 002, CPLDB Version is 005
BootRom Version is 220
[SubSlot 0] 24SFP Plus+2GE Hardware Version is Ver.B
Desired Config:
ip vpn-instance app-vprn110
route-distinguisher 192.168.0.1:1158
description 'VRF Up_HP_App_1'
ip vpn-instance oam-vprn10
route-distinguisher 192.168.0.25:1160
description 'VRF Up_HP_OAM_1'
interface GigabitEthernet0/0/2
port link-mode route
combo enable copper
interface GigabitEthernet0/0/2.1158
ip binding vpn-instance app-vprn110
ip address 192.168.0.2 255.255.255.252
interface GigabitEthernet0/0/2.1160
ip binding vpn-instance oam-vprn10
ip address 192.168.0.26 255.255.255.252
ip route-static vpn-instance app-vprn110 0.0.0.0 0 192.168.0.1
ip route-static vpn-instance oam-vprn10 0.0.0.0 0 192.168.0.25
Michael
