Comware
HP 5900 Comware v7 Network Monitoring Software
  • 1.  HP 5900 Comware v7 Network Monitoring Software
    Posted Mar 21, 2018 02:50 AM
    Trying to configure network monitoring software for the HP 5900 series switches. I tryied using PRTG, Cacti and Managengine. The interfaces are discovered correctly and also the throughput on the interface, but this doesnt give the complete view of the device. MIssing is the CPU, memory and other environment (temp, power etc), can add them to prtg via the mib importer but they dont create a meaningful sensor without alot configuring.
    Other then HP iMC, is there any other network monitoring software that works with HP comware v7 nativity? (eg like adding a cisco device to prtg)
    #NetworkMonitoring
    #comware
    #5900
  • 2.  RE: HP 5900 Comware v7 Network Monitoring Software
    Posted Mar 21, 2018 07:02 AM
    Hello Draven,
    Try observium or the opensource librenms
