As per the this product quick specs, below are the supported transceivers. Regarding the 3rd pary tranceivers, generally HP/HPE does not garantee the functionality of the SFP.
Quick specs: https://h20195.www2.hpe.com/v2/GetPDF.aspx/c04111706.pdf
HP 6600-24XG Switch J9265A
24 open 10-GbE SFP+ transceiver slots
min=0 \ max=24 SFP+ Transceivers
Note 1
The following SFP+ Transceivers install into this switch:
HP X132 10G SFP+ LC ER Transceiver J9153A
HP X132 10G SFP+ LC LR Transceiver J9151A
HP X132 10G SFP+ LC LRM Transceiver J9152A
HP X132 10G SFP+ LC SR Transceiver J9150A
HP X242 10G SFP+ to SFP+ 1m Direct Attach Copper Cable J9281B
HP X242 10G SFP+ to SFP+ 3m Direct Attach Copper Cable J9283B
HP X242 10G SFP+ to SFP+ 7m Direct Attach Copper Cable J9285B
HP X244 10G XFP to SFP+ 1m Direct Attach Copper Cable J9300A
HP 10G X244 XFP to SFP+ 3m Direct Attach Copper Cable J9301A
HP 10G X244 XFP to SFP+ 5m Direct Attach Copper Cable J9302A
HP X242 10G SFP+ to SFP+ 10m Direct Attach Copper Cable J9286B
HP X242 10G SFP+ to SFP+ 15m Direct Attach Copper Cable J9287B
Note 2
The following SFP Transceivers install into this switch:
HP X121 1G SFP LC SX Transceiver J4858C
HP X121 1G SFP LC LX Transceiver J4859C
HP X121 1G SFP LC LH Transceiver J4860C
HP X112 100M SFP LC BX-D Transceiver J9099B
HP X112 100M SFP LC BX-U Transceiver J9100B
HP X122 1G SFP LC BX-D Transceiver J9142B
HP X122 1G SFP LC BX-U Transceiver J9143B
HP X111 100M SFP LC FX Transceiver J9054C
