Comware
HP 830 8P (JG641A)
  • 1.  HP 830 8P (JG641A)
    Posted May 15, 2023 12:47 PM
    Hi to all. I tried to find the latest firmware for it, unfortunately found nothing. Maybe anyone can help with a link for it?
  • 2.  RE: HP 830 8P (JG641A)
    Posted May 16, 2023 03:26 PM
    The latest and last version of the  HP 830 8-Port PoE+ Unified Wired-WLAN Switch is  HP830_5.20.R3507P73.
    This version was released in 2021. If you are already using this version then you are up to date because the product is end of engineering support and there will be no newer versions.
    There is no public link for a firmware download any longer. If your device is entitled to support, you can try to obtain the firmware from your local support.
  • 3.  RE: HP 830 8P (JG641A)
    Posted May 16, 2023 04:08 PM
    Thank you for answer. I checked  version of my HP 830 8-port and it is "Version 5.20, Release 3308P29"
    Is there a chance to get updates through contacting support? We bought this device for more than 5 years ago.
