I do not believe that is supported at this point.
In the current release, they do support AP provisioning (preloading config on AP to change e.g. the AP management vlan id or a tagged management vlan or define the AP uplink as a vlan trunk), so this would allow the loading of the settings onto the AP.
However, since comware does not have a dot1x supplicant (client), we are stuck at this point (as far as I know).
Best regards,Peter.
