Network Management
HP Aruba 2530 series
This thread has been viewed 16 times
  • 1.  HP Aruba 2530 series
    Posted Jan 05, 2022 11:11 AM
    Hi there
    I have a port on HP aruba 2530 series which continuously flaps when pc connected. I troubleshooted the cable and it was fine, also checked vlan dhcp server and it worked fine but the user got 169.254.x.x ip when connected on this port.
    I 11/21/21 04:00:38 00077 ports: port 17 is now off-line
    I 11/21/21 04:00:26 00076 ports: port 17 is now on-line
    I 11/21/21 04:00:22 00077 ports: port 17 is now off-line
    I 11/21/21 04:00:22 00076 ports: port 17 is now on-line
    I 11/21/21 01:00:31 00077 ports: port 17 is now off-line
    I 11/21/21 01:00:23 00076 ports: port 17 is now on-line
    I 11/21/21 01:00:21 00077 ports: port 17 is now off-line
    I 11/20/21 22:27:49 00076 ports: port 17 is now on-line
    I 11/20/21 22:27:46 00077 ports: port 17 is now off-line
    I 11/20/21 22:27:45 00076 ports: port 17 is now on-line
    I 11/20/21 22:27:42 00077 ports: port 17 is now off-line
    I 11/20/21 22:27:40 00076 ports: port 17 is now on-line
    I 11/20/21 22:27:34 00077 ports: port 17 is now off-line
    I 11/20/21 22:27:32 00076 ports: port 17 is now on-line
    I 11/20/21 15:48:44 00077 ports: port 17 is now off-line
    The content of this email is considered privileged. If you are not its intended recipient, please notify the sender and delete all copies immediately.
  • 2.  RE: HP Aruba 2530 series
    Posted Jan 06, 2022 09:45 AM
    Is that for all devices connected to the switch? Or a specific.
    Does the same happen on all the ports of the switch?
    The logs suggest that the client drops the connection. Support may have commands to check deeper.
  • 3.  RE: HP Aruba 2530 series
    MVP GURU
    Posted Jan 10, 2022 10:18 AM
    Hi! It looks like something is going on at device's NIC level (Are Firmware/OS NIC drivers fully updated? is the NIC configured at OS level to disable the port to save energy - AKA sleep mode - when no traffic is flowing through?), the fact the port is flapping without any Spanning Tree reference logged (with the typical blocking->forwarding learning cycle) maybe is due exactly to NIC port on the connected edge device (PC). If I were you I will triple check all on that side (from physical cabling up to NIC's configuration not excluding a check about NIC driver and firmware versions).
    Davide Poletto
