Network Management
HP Aruba 2920 Stack - Config backup and Firmware upgrade
  • 1.  HP Aruba 2920 Stack - Config backup and Firmware upgrade
    Posted Feb 16, 2024 10:10 AM
    Hi All,
    There are two HP Aruba 2920 switches combined in stack.
    Could you please help with:
    1. Is it possible to take a backup of the current config via WebUI or it can be done only by copying the output of the show running-configuration command in terminal?
    2. Is firmware upgrade applies to both members of the stack? (Most likely yes as in the WebUI I don't see an option to upgrade each member individually but just want to double-check.)
    Thanks.
  • 2.  RE: HP Aruba 2920 Stack - Config backup and Firmware upgrade
    Posted Feb 16, 2024 10:31 AM
    I have a 2930 stack (WC.16.10.0012 software version) . I assume it would be close to the same thing.
    1. http://[IP address ]/nextgen/ui/index.html#/configReport - Gets you to the Configurations - Config Report (default shows running-config but you can choose a saved config)
     - It spits out text that you can copy to a text file
    2. http://[ IP address ]/nextgen/ui/index.html#/update - Gets you to the System - Firmware Update section that shows you what version is on your primary and secondary boot. If you change the firmware of the commander, it will automatically change the firmware of the standby stack units
