Wired Intelligent Edge
HP ARUBA 2930F SWITCH
  • 1.  HP ARUBA 2930F SWITCH
    Posted Feb 23, 2018 06:16 PM
    I am new to this community and wanted to learn more about hp switches
    Currently we have hp 2930 as stacks using chain topolgy.
    We have several vlan setups.
    I am struggling to configure member 2 in the stack through the commander.
    For example if I want to configure a port which is located on switch member 2 port 2/34 onto (vlan office) from (Vlan Reception) what are the commands.
    If someone can tell me step by step commands please much appreciated.
    Regards
  • 2.  RE: HP ARUBA 2930F SWITCH
    MVP EXPERT
    Posted Feb 24, 2018 06:17 AM
    Are these all part of the same VSF?
  • 3.  RE: HP ARUBA 2930F SWITCH
    Posted Feb 26, 2018 05:11 AM
    On ArubaOS switches, you configure the VLAN and then attach ports to it either untagged or tagged.
    For example if your Office VLAN is VLAN2, and port 1/8, 2/2 through 2/5 must be access ports in that VLAN, and port 1/5 is the (tagged) uplink, the config could be like this:
    vlan 2
       name "Office"
       untagged 1/8,2/2-2/5
       tagged 1/5
       ip address 10.254.1.1 255.255.255.0
       exit
    Is that what you are looking for?
