Wired Intelligent Edge
HP Aruba 8100 switch VLAN Issue
  • 1.  HP Aruba 8100 switch VLAN Issue
    Posted Jun 17, 2024 02:25 PM
    Hi All,
    I would appreciate your help to resolve the VLAN issue. I have replaced the Cisco Catalyst 2960X switch with the HP Aruba 8100 Switch. But have a VLANs passing challenge.
    VLAN Configuration on Aruba 8100
    VLAN1
    VLAN100
    Interface 1/1/24-28 Trunk, Native Untagged, Allowed ALL
    BGTSW12(config-if)# show vlan
    VLAN  Name                              Status  Reason                  Type        Interfaces
    1     DEFAULT_VLAN_1                    up      ok                      default     1/1/1-1/1/28
    100   BGT-Guest                             up      ok                      static      1/1/24-1/1/28
    BGTSW12(config-if)# show interface 1/1/25-1/1/28 brief
    Port           Native  Mode   Type             Enabled Status  Reason                  Speed   Description
                   VLAN        (Mb/s)
    1/1/25         1       trunk  1G-LX            yes     up                              1000    --
    1/1/26         1       trunk  1G-LX            yes     up                              1000    --
    1/1/27         1       trunk  1G-LX            yes     up                              1000    --
    1/1/28         1       trunk  1G-LX            yes     up                              1000    --
  • 2.  RE: HP Aruba 8100 switch VLAN Issue
    MVP GURU
    Posted Jun 17, 2024 03:11 PM
    Hello, what is your challenge, exactly? If I'm not mistaken you didn't wrote what the issue is (at least I don't see described an As-Is versus To-Be scenario...or something like that)...and we can't really guess.
    Generally speaking - especially when VLAN(s) should be allowed to pass through downlinks/uplinks - you should try to reproduce - on the new device (Aruba CX 8100) with respect to the old device you're going to replace - the "VLAN membership" of involved port(s), either on ports operating in Access Mode (one VLAN only, either untagged or tagged) or on ports operating in Trunk Mode (one or more VLANs).
    Do you have issue related to that? what is the Cisco configuration?
