Wired
HP Aruba Switch 8100 VLAN issue
  • 1.  HP Aruba Switch 8100 VLAN issue
    Posted Jun 17, 2024 07:02 PM
    Hi All,
    I would appreciate your help to resolve the VLAN issue. I have replaced the Cisco Catalyst 2960X switch with the HP Aruba 8100 Switch. But have a VLANs passing challenge.
    VLAN Configuration on Aruba 8100
    VLAN1
    VLAN100
    Interface 1/1/24-28 Trunk, Native Untagged, Allowed ALL
    BGTSW12(config-if)# show vlan
    VLAN  Name                              Status  Reason                  Type        Interfaces
    1     DEFAULT_VLAN_1                    up      ok                      default     1/1/1-1/1/28
    100   BGT-Guest                             up      ok                      static      1/1/24-1/1/28
    BGTSW12(config-if)# show interface 1/1/25-1/1/28 brief
    Port           Native  Mode   Type             Enabled Status  Reason                  Speed   Description
                   VLAN        (Mb/s)
    1/1/25         1       trunk  1G-LX            yes     up                              1000    --
    1/1/26         1       trunk  1G-LX            yes     up                              1000    --
    1/1/27         1       trunk  1G-LX            yes     up                              1000    --
    1/1/28         1       trunk  1G-LX            yes     up                              1000    --
  • 2.  RE: HP Aruba Switch 8100 VLAN issue
    Posted Jun 18, 2024 02:56 PM
    Hello
    Can you post your 'show run' on 8100. Remove sensitive data.
  • 3.  RE: HP Aruba Switch 8100 VLAN issue
    Hello
    Can you post your " show run" on 8100 remove sensitive data, or unnecessary data,
