Comware
  • 1.  HP Aruba to other Vendors
    Posted Oct 30, 2021 07:58 AM
    We are trying to connect HP Procurve Switch to another vendor product (Huawei) but it shuts the whole subnet behind HP switch down the time we connect the network cable between the switches. After checking the logs in the HP core switch we found that STP is blocking the port which is connected to the Procurve switch. We changed the STP settings for the specific port in the core switch by running the below command but still the same.
    no spanning-tree bpdu-filter
    The port on the ProCurve switch connected to the Huawei switch is untagged for the VLAN required for Huawei.
    Any suggestions?
    #Port
    #Aruba
  • 2.  RE: HP Aruba to other Vendors
    Posted Oct 30, 2021 01:24 PM
    In Procurve untagged=Access port and if Huawei is switch then it should be tagged on Procurve side.
    And any other STP setting on Procurve switch?
    Thanks!
  • 3.  RE: HP Aruba to other Vendors
    Posted Oct 31, 2021 09:57 AM
    Tagging the access port is not allowing the PC to get an IP address from DHCP. What should be the mode of the uplink port for the Huwaei VLAN? I mean uplink from Procurve to core.
  • 4.  RE: HP Aruba to other Vendors
    Posted Oct 31, 2021 10:02 AM
    STP on the core switch is still blocking the port connected to ProCurve after connecting the Huawei switch.
  • 5.  RE: HP Aruba to other Vendors
    Posted Oct 31, 2021 02:57 PM
    Hello @csadmin77 ,
    Which switch root switch in the topology?
    Or only these two switches itnerconnected?
    Can you share 'show spanning-tree' output?
    Thanks!
  • 6.  RE: HP Aruba to other Vendors
    Posted Oct 31, 2021 05:57 PM
    It started working after I ran
    spanning-tree port# bpdu-filter
    on the core switch port connected to the ProCurve Switch. I kept the access port as untagged but the uplink port as tagged. Don't know if it is correct or not but it is not going down now.
    When i am running show spanning-tree bpdu-protection now, I am getting the below results for the changed port
    100/1000T No Forwarding 10152
    The number 10152 is shown under Errant.
    Thanks.
  • 7.  RE: HP Aruba to other Vendors
    Posted Nov 01, 2021 09:15 AM
    Hello @csadmin77 ,
    Both side is switch so I believe both side it should be same type. So tagged(trunk) other end as well.
    Can you share full output and what you are seeing under 'show log':
    show spanning-tree
    show log
    Thanks!
