Comware
HP Comware Lab L2VPN Support
  • 1.  HP Comware Lab L2VPN Support
    Posted Jun 08, 2015 04:07 PM
    Any idea whether the new HP Comware Lab (7.1.59) supports L2VPN?
    I'm asking as I'm pretty sure that the previous version didn't.
    Peter
  • 2.  RE: HP Comware Lab L2VPN Support
    Posted Jun 10, 2015 10:19 AM
    Hello Peter,
    7.1.59 does not. You can configure it, but no traffic seems to go through (e.g. after sending a ping one side shows the partners MAC in ARP table, other side does not, seems like unidirectional traffic?).
    Same for VPLS.
    Best regards,
    Ingo
  • 3.  RE: HP Comware Lab L2VPN Support
    Posted Mar 16, 2017 08:00 AM
    To my experience MPLS L2VPN as well as VXLAN/EVPN do not work with bridged-ports in the simulator; can be configured but traffic is not flowing. However they work perfectly using a routed port towards the end-node.
    Try for having traffic untagged / access port:
    interface GigabitEthernet1/0/1
    port link-mode route
    xconnect vsi <VSI-Name>
    Example adding a tagged VLAN; use a sub interface:
    interface GigabitEthernet1/0/1.10
    vlan-type dot1q vid 10
    Best use a router manual for reference on the setup, i.e. VSR1000 manuals.
    Ingo
