Network Management
  • 1.  HP IMS SMS Alerts
    Posted Jun 04, 2012 05:59 AM
    Hi All,
    I have a single server HP IMC version 5.0 installed at a customer. I have setup email alerts and all works 100%.
    I need to setup SMS alerts. I have a USB Huawei Modem and an open SIM
    I followed the Admin guide process, which is very simple, but cannot get this working. Any help would be greatly appreciated.
    Thanks in Advance
    Kavesh.B
    #modem
  • 2.  RE: HP IMS SMS Alerts
    Posted Jun 05, 2012 04:51 AM
    USB Huawei Modem is not supported. See the release notes for modem compatibility.
  • 3.  RE: HP IMS SMS Alerts
    Posted Jun 07, 2012 09:05 AM
    Hi, can you perhaps help me with this list....I have checked through thte release notes for 5.0 and5.1, and cannot find a list of supported modem.
  • 4.  RE: HP IMS SMS Alerts
    Posted Jun 07, 2012 09:53 PM
    To my knowledge, the following modems are being supported in IMC 5.1SP1, which will be released recently. Maybe you could have a try.
      WaveCom M2306B
    · WaveCom TS-WGC1 (Q2403A)
    · Wanxiang serial port GSM modem (DG-C1A)
    · Wanxiang USB GSM modem (DG-U1A)
    · Wanxiang USB min GSM modem (DG-MINI)
    · WaveCom M1206B GSM modem (chip: 24PL)
    · WaveCom USB M1206B GSM modem (chip: Q24PL, Q2403A)
    Good luck!
  • 5.  RE: HP IMS SMS Alerts
    Posted May 26, 2015 06:29 AM
    I thought that I also put some input into this board. So, for all guys that come back to this question:
    We resolved SMS alerts thing using a hardware SMS gateway. We send alerts from IMC as emails and convert them to SMS messages in the SMS gateway. We have a hardware gateway for that with email2sms plugin. This is what we used: http://www.smseagle.eu  It does the job well.
    Pierre
    #SMS
  • 6.  RE: HP IMS SMS Alerts
    Posted Mar 13, 2017 07:26 AM
    Hi guys:
      We are needing to send SMS alerts from HP IMC.
    The options to send SMS are poor documented and really need some extra explanations to be used...
    Can you help me with such options?
    Can I generate a POST or GET to an URL for each SMS that need to be sended for example?
    There are a official list of SMS GATEWAYS or gsm modem chipsets compatible with HP IMC?
    Any help in this regard will be highly appreciated.
    Thanks in advance.
    Hugo Müller
