HY everyone.
I have a problem with my msm 430 after upgrading.
The previous version was 5.5.1
I upgraded to the newest one, and now my VSC clients can see each other any more.
I have 3 VSCs:
VSC1 - 5GHZ radio(for forcing to connect on 5GHZ on specific devices for speed)
VSC2 - 2.4GHZ (everybody else with wifi capabilities)
VSC3 - printserver on 2.4 GHZ radio (2 wireless WSD enabled printers.)
I had no VLANs, just the basic setup .
A router with DHCP is on 192.168.1.1 and the AP is connected to this router on gigabit.STATIC IP 192.168.1.11 gateway set to 192.168.1.1
It was working fine, every client saw each other, and everybody could print to the printers on the printserver VSC3.
But since the update a client on the VSC1 cant ping a client on VSC2 or 3.
But a client on the routers another gigabit port(server PC) can ping everybody on VSC1 VSC2 or VSC3.
The only problem is that the clients cant reach clients on other VSC-s.
Is there anything that chaged in this firmware or should i just do a factory reset a configure it again?
I have no controller, just the AP in autonomus mode.
I want to be able to set the AP to allow traffic between the VSC-s.
2 client on the same VSC can see each other and ping with no problem.
Any help will be appreciated.
Thank You,
David M
#DHCP#msm430#VSC#upgrade#VLAN
