HP MSM466 Odd Blinking, no connectivity
  • 1.  HP MSM466 Odd Blinking, no connectivity
    Posted May 09, 2023 11:47 AM
    Greetings,
    i just got some MSM466 WW from my workplace, they where still in original hp packing. Sadly i cant use any of them since they dont start properly.
    Product Number J9622A
    Model MRLBB-1002
    The Power LED is nearly instantly on, Network and Radio Blinking together, Radio 2 Blinks independently.
    Factory reset does not work.
    IP is not Pingable.
    Serial Console also gives me no output.
    I hope someone can help me here, since im just a home user HP wont do anything for me...
    Thank you all
  • 2.  RE: HP MSM466 Odd Blinking, no connectivity
    Posted May 10, 2023 09:39 AM
    From this document:  https://support.hpe.com/hpesc/public/docDisplay?docId=c04915287
    Those lights mean "The AP has obtained an IP address and isattempting to discover a controller."
    If you don't have a controller to go with those MSM access points, you're not going to be able to get them to do anything.  If you do have a controller, then the next step would be to try to debug why the AP can't seem to talk to the controller.
