Comware
  • 1.  HP MSR2003 connect to Cisco Switch?
    Posted Feb 04, 2020 11:49 AM
    I have been trying to look-up if it is possible to use an MSR2003 router and a Cisco switch. All I have found is cisco to hp switch. I have a project where multiple Vlans will be in 2 different cisco switches. I have never used HP equipment and can't find much information online. Any suggestions would be great.
    #802.1Q
    #switch
    #router
    #HProuter
    #cisco
  • 2.  RE: HP MSR2003 connect to Cisco Switch?
    Posted Feb 04, 2020 06:21 PM
    Please show us your desired network topology (you're mixing the MSR2003 Router with your Layer 2 - eventually Layer 3 - Cisco Switches...there is not - a-priori - an incompatibility but you need to explain what is going to be your intended network topology in order to correctly place the Router and Switches).
