Comware
  • 1.  HP OfficeConnect 1920 (JG925A): force enable PoE regardless of what is plugged into a port
    Posted May 03, 2017 11:42 AM
    We need to power custom hardware which fails to properly negotiate PoE due to its design. Some switch vendors have an option to force "always-on" PoE mode on their products and it works for us. However, HP OC1920 (JG925Y) seems to be missing such an option. Is it possible to achieve always-enabled PoE state on this device? Are we missing something? Maybe we need a custom firmware or something like that?
    Any help would be very appreciated.
    Thanks.
    #PoE
    #1920
    #JG925A
  • 2.  RE: HP OfficeConnect 1920 (JG925A): force enable PoE regardless of what is plugged into a port
    Posted May 10, 2017 03:03 AM
    I spoke with HPE support and was informed that the functionality I seek is not supported on HP devices. So there's that, I guess.
  • 3.  RE: HP OfficeConnect 1920 (JG925A): force enable PoE regardless of what is plugged into a port
    Posted May 16, 2017 11:45 AM
    What if you disbaled PoE on the port but then used a PoE injector? - is that not a dumb device that will supply power on the appropriate pin to your end device?
  • 4.  RE: HP OfficeConnect 1920 (JG925A): force enable PoE regardless of what is plugged into a port
    Posted May 17, 2017 08:39 AM
    @Dunky yeah, but that kinda defeats the purpose of paying for a PoE-capable switch.
