Hi everyone,
I've got PCM 4+ running in a Hyper-V VM and have recently moved the workload to another Hyper-V Server.
This resulted in the PCM4+ VM creating a second NIC.
Now every time PCM 4+ client starts up it returns:
"Check the management server. It appears to not be running. You may need to restart the HP PCM Server service from the control panel services dialog. You must also select a management server from this list if you are starting a remote client for the first time".
Any ideas?
#Hyper-V
