Wired Intelligent Edge
  • 1.  HP procurve 2610 Console problem
    Posted May 21, 2013 07:12 PM
    Hello
    I m trying to connect switches with console connection but unforunatly all switches have same problem i tested on more than 32 procurve 2610 POE switches but all have same problem when i connect console using Serial to USB connector and Terminal emulator is Putty operating system Win 7 Professional switch cli give me some thing like this
    waiting for speed sense press twice enter
    after press enter nothing happen cli hanged.
    i dont know whats going on i checked with 9600 2400 11500
    please suggest me how i can connect.
    #putty
    #Console
    #hp2610
    #ProCurve
  • 2.  RE: HP procurve 2610 Console problem
  • 3.  RE: HP procurve 2610 Console problem
    Posted May 21, 2013 07:22 PM
    thank u
    but i try this 5 6 times on diffrent switches but same result :(
  • 4.  RE: HP procurve 2610 Console problem
    Posted May 21, 2013 07:49 PM
    Have you got Putty set to the correct COM port?The USB converter thing doesn't tell you what COM port it has selected.
    Those USB converter things are pretty annoying - I keep a laptop with a proper serial port so I don't have to rely on them. They add a level of unreliability that I find unacceptable. And then their contacts wear out and they get even worse.
    Make sure you have Flow control set to None. Speed 9600 is correct.
  • 5.  RE: HP procurve 2610 Console problem
    Posted May 21, 2013 07:59 PM
    @ Vince here is config which i am using
    please check attached pic
    is it ok
  • 6.  RE: HP procurve 2610 Console problem
    Posted May 23, 2013 09:31 AM
    i m tired to do this do that what the problem with HP i test my cable and port on CISCO switch working good now i m tired i ll  replace switch with CISCO because no one know how and dont have good knowledge about HP even thier custmer service i called them no relaiable answer.
    today i try with Hyper Terminal same result when i change baud rate switch give me alien language.
