Hello, have a look here. The part for you is (once in config mode):
trunk 25,26 trk1 lacp
the logical interface "trk1" (aggregated interface) will be created using physical member interfaces 25 and 26 as member and LACP will be the Link Aggregation Control Protcol used.
Remeber that, from the VLAN ownership standpoint, the new trk1 interface could be managed exactly like you manage other physical interfaces, so you can assign it
to specific untagged VLAN or tagged VLAN or a mix of them (untagged VLAN + tagged VLAN(s)) as per the example in the linked page (assigning an IP is not necessary).
Original Message:
Sent: May 15, 2024 07:28 AM
Subject: HP ProCurve 2626 J4900B Link Aggregation (LACP) Help
Hello friends. I need your help with Link Aggregation(LACP). This switch has a Link Aggregation feature but i can not configure it from the web interface. Configuration must be done from cli. Unfortunately, i am not good at cli commands :( Can you write me please how can i do it? I need 25 and 26 gigabit ports for LACP. Thanks in advance.
