Wired Intelligent Edge
  • 1.  HP Procurve 2626 VLANs
    Posted May 02, 2016 06:55 AM
    Hi
    I have a HP Procurve 2626 based series and I'm having problems with it. I've simplifed my lab to start from the begining.
    I have a router when I have VLAN 10 by ethernet 3. This is plugged to HP SW to port 1. And a laptop plugged to port 2 in the HP SW.
    Kind of this:
    Router-> ethernet 3 -> HP SW port 1 --> ethernet port 2 -> Laptop
    I've setup the vlan 10 in router. And then in the HP SW I have the default VLAN and the other I created VLAN 10. I did to test. One tagging port 2 and untagging port 2 (Both times I run config# memory write) No ip is given to the client.
    At the end, I tried to setup manually IP on client. and ping the vlan 10 ip address on routher, no success. Then I googled and I saw some post about  HP switches and sound interesting to me, but no success.
    http://www.techieshelp.com/setup-dhcp-helper-on-hp-e-series/
    My setup in router is
    ethernet port 3
    0 10.0.1.1/24 10.0.1.0 eth3
    vlan
    10.0.2.1/24 10.0.2.0 vlan10
    dhcp server
    dhcp2 vlan10 dhcp_pool1 3d
    1 dhcp_pool1 10.0.2.2-10.0.2.254
    Did I miss something?
    Thanks!
    #2626
    #ProCurve
  • 2.  RE: HP Procurve 2626 VLANs
    Posted May 08, 2016 05:43 PM
    Assuming your HP switchport 1 has VLAN 10 on it as tagged, then there is probably something screwy with your router.
