Wired Intelligent Edge
  • 1.  HP Procurve 5308xl inter-vlan routing; no internet
    Posted Jul 30, 2014 03:20 PM
    Environment:
    • 1 - 5308xl Switch (IP: 10.0.0.254; 10.0.1.254; 10.0.2.254; 10.0.3.254; 10.0.4.254; 10.0.10.254; 10.1.10.254)
    • 1 - modem (IP: 10.1.10.10)
    • 1 - DHCP server (IP: 10.0.0.1, 10.0.1.1; 10.0.2.1; 10.0.3.1; 10.0.4.1; 10.0.5.1; 10.0.10.1; 10.1.10.1)
    • 2 - Clients (one on vlan 40 and one on vlan 254)
    The problem:
    I have inter-vlan routing turned on, each vlan is able to ping each other, but only the devices connected to the vlan that the modem resides on is able to ping the modem and get onto the internet. I had a rep from our ISP look at my modem config and verify that nothing there should hinder my ability to get onto the internet.
    Switch configuration:
    ; J4819A Configuration Editor; Created on release #E.11.38
    hostname "Switch"
    time timezone -360
    time daylight-time-rule Continental-US-and-Canada
    fastboot
    module 8 type J4878B
    module 1 type J4820B
    module 3 type J4820B
    module 5 type J4820B
    module 7 type J4820B
    module 4 type J4820A
    module 2 type J4820A
    module 6 type J4820A
    interface F2
       name "Modem"
    exit
    interface F3
       name "DHCP"
    exit
    interface F4
       name "CUPS"
    exit
    interface F5
       name "UNIFI"
    exit
    interface F6
       name "Server"
    exit
    sntp server 10.0.10.5
    ip routing
    timesync sntp
    sntp unicast
    sntp 30
    logging facility syslog
    logging 10.0.10.8
    snmp-server community "public" Unrestricted
    vlan 1
       name "DEFAULT_VLAN"
       untagged A1-A6,A8-A24,B1-B24,C1-C24,D1-D24,E11-E24,F1,F9-F24,G1-G24,H1-H4
       ip address 10.0.0.254 255.255.255.0
       no untagged A7,E1-E10,F2-F8
       exit
    vlan 10
       name "Student Lan"
       ip address 10.0.1.254 255.255.255.0
       ip helper-address 10.0.1.1
       tagged F3
       exit
    vlan 20
       name "Staff Lan"
       ip address 10.0.2.254 255.255.255.0
       ip helper-address 10.0.2.1
       tagged F3
       exit
    vlan 30
       name "Student WiFi"
       ip address 10.0.3.254 255.255.255.0
       ip helper-address 10.0.3.1
       tagged E1-E6,F3,F5
       exit
    vlan 40
       name "Staff WiFi"
       ip address 10.0.4.254 255.255.255.0
       ip helper-address 10.0.4.1
       tagged E1-E6,F3,F5
       exit
    vlan 50
       name "Guest WiFi"
       ip address 10.0.5.254 255.255.255.0
       ip helper-address 10.0.5.1
       tagged E1-E6,F3,F5
       exit
    vlan 100
       name "Servers and Devices"
       untagged E1-E10,F4-F6
       ip address 10.0.10.254 255.255.255.0
       ip helper-address 10.0.10.1
       tagged F3
       exit
    vlan 254
       name "Outside"
       untagged A7,F2-F3,F7-F8
       ip address 10.1.10.254 255.255.255.0
       exit
    ip route 0.0.0.0 0.0.0.0 10.1.10.10
    spanning-tree
    ip ssh
    no tftp client
    no tftp server
    password manager
    password operator
    DHCP server config:
    option domain-search "ns.example.loc";
    # Lease time is in seconds.
    # Current settings: default-lease-time 12 hours
    default-lease-time 43200;
    max-lease-time 43200;
    # If this DHCP server is the official DHCP server for the local
    # network, the authoritative directive should be uncommented.
    authoritative;
    # Use this to send dhcp log messages to a different log file (you also
    # have to hack syslog.conf to complete the redirection).
    log-facility local7;
    ### BEGIN VLAN ADDRESSING SCHEME
    # Vlan 1: Management
    subnet 10.0.0.0 netmask 255.255.255.0 {
    	range 10.0.0.100 10.0.0.200;
    	option routers 10.0.0.254;
    	option domain-name-servers 10.0.0.1, 8.8.8.8; # , 208.67.220.220;
    # Vlan 10: Student
    subnet 10.0.1.0 netmask 255.255.255.0 {
    	range 10.0.1.50 10.0.1.200;
    	option routers 10.0.1.254;
    	option broadcast-address 10.0.1.255;
    	option lpr-servers 10.0.10.8;
    	option domain-name-servers 10.0.1.1, 208.67.222.222, 208.67.220.220;
    # Vlan 20: Staff
    subnet 10.0.2.0 netmask 255.255.255.0 {
    	range 10.0.2.50 10.0.2.200;
    	option routers 10.0.2.254;
    	option broadcast-address 10.0.2.255;
    	option domain-name-servers 10.0.2.1, 8.8.8.8; # 208.67.222.222, 208.67.220.220;
    # Vlan 30: WiFi_Student
    subnet 10.0.3.0 netmask 255.255.255.0 {
    	range 10.0.3.50 10.0.3.200;
    	option routers 10.0.3.254;
    	option broadcast-address 10.0.3.255;
    	option domain-name-servers 10.0.3.1, 208.67.222.222, 208.67.220.220;
    # Vlan 40: WiFi_Staff
    subnet 10.0.4.0 netmask 255.255.255.0 {
    	range 10.0.4.50 10.0.4.200;
    	option routers 10.0.4.254;
    	option broadcast-address 10.0.4.255;
    	option domain-name-servers 10.0.4.1, 208.67.222.222, 208.67.220.220;
    # Vlan 50: WiFi_Guest
    subnet 10.0.5.0 netmask 255.255.255.0 {
    	range 10.0.5.50 10.0.5.200;
    	option routers 10.0.5.254;
    	option broadcast-address 10.0.5.255;
    	option domain-name-servers 208.67.222.222, 208.67.220.220;
    # Vlan 100: Servers and printers
    subnet 10.0.10.0 netmask 255.255.255.0 {
    	range 10.0.10.50 10.0.10.200;
    	option routers 10.0.10.254;
    	option broadcast-address 10.0.10.255;
    	option domain-name-servers 10.0.10.1, 8.8.8.8;
    # Vlan 254: Outside
    subnet 10.1.10.0 netmask 255.255.255.0 {
    	range 10.1.10.50 10.1.10.200;
    	option routers 10.1.10.254;
    	option broadcast-address 10.1.10.255;
    	option domain-name-servers 10.1.10.1;
    #internet
    #ProCurve
    #unreachable
    #modem
    #VLAN
    #5308xl
    #routing
  • 2.  RE: HP Procurve 5308xl inter-vlan routing; no internet
    Posted Jul 30, 2014 07:07 PM
    Your modem needs a route, eg,
    10.0.0.0 255.255.0.0 10.1.10.254
  • 3.  RE: HP Procurve 5308xl inter-vlan routing; no internet
    Posted Jul 31, 2014 10:18 AM
    Vince,
    thank you for your reply.
    Putting your suggestion into the switch gives me the following:
    10.1.10.254 can not be switch IP address and route gateway at the same time.
    Edit: I think I understand what you were saying, you were telling me to add a static route to the modem. The modem now contains the following static route
    Now all vlans are able to ping the modem (yay!)
    Unfortunately; no vlan except 254 can reach the outside internet:
    From vlan 40:
    traceroute 8.8.8.8
    traceroute to 8.8.8.8 (8.8.8.8), 64 hops max, 52 byte packets
     1  10.0.4.254 (10.0.4.254)  4.844 ms  12.724 ms  2.259 ms
     2  10.1.10.10 (10.1.10.10)  1.626 ms  5.411 ms  6.300 ms
     3  * * *
     4  * * *
     5  * * *
     6  * * *
     7  * * *
     8  * * *
     9  * * *
  • 4.  RE: HP Procurve 5308xl inter-vlan routing; no internet
    Posted Jul 31, 2014 03:56 PM
    Now you probably have to look at your NAT config on the modem.
  • 5.  RE: HP Procurve 5308xl inter-vlan routing; no internet
    Posted Aug 06, 2014 12:57 PM
    Just solved this today. The solution was not in the switch, but in my modem. After adding a route back to the switch for the 10 network, I needed to make sure the subnetting was correct for the modem's ip address.
    So before it was
    10.1.10.10 255.255.255.0
    now it is
    10.1.10.10 255.0.0.0
    And all is well.
    Thank you Vince for helping me out this far.
