Wired Intelligent Edge
HP Procurve 6600-24G-4XG ***Telnet problem***
  • 1.  HP Procurve 6600-24G-4XG ***Telnet problem***
    Posted Nov 18, 2016 08:39 AM
    I have a problem with telnet connection on my HP Procurve 6600-24G-4XG. I can't ping switch from my lap top until I ping myself from switch using serial login. After that I can login using telnet, but after few minutes, everything freezes...
    Any ideas??
    Thank you,
    Gojko
    #telnet
  • 2.  RE: HP Procurve 6600-24G-4XG ***Telnet problem***
    Posted Nov 18, 2016 09:43 AM
    Hi Gojkog21,
    Would you be able to post your switch configuration file ("show running-config")? That would greatly help us to provide guidance.
    Shaun
  • 3.  RE: HP Procurve 6600-24G-4XG ***Telnet problem***
    Posted Dec 06, 2016 04:26 PM
    It's solved with firmware update.
