Wired Intelligent Edge
  • 1.  HP Procurve Switch 2530 Can't open web interface
    Posted Apr 24, 2014 08:29 AM
    Hi all,
    For some reason I can't open HP switch web interface. I've just connected it for  the first time to the production  network, it got an IP from DHCP but can't open web interface. Telnet works fine.  Any help?
    Kind Regards,
    Dmitri
    P.S. This thread has been moevd from Switches, Hubs, Modems (Legacy ITRC forum) to ProCurve / ProVision-Based. - Hp Forum Moderator
    #EWS
  • 2.  RE: HP Procurve Switch 2530 Can't open web interface
    Posted May 06, 2014 08:25 AM
    Is webmanagement enable???
    If not, type this in a telnet session.
    conf t
    webmanagement
  • 3.  RE: HP Procurve Switch 2530 Can't open web interface
    Posted Jul 30, 2017 01:55 AM
    Web Management for HTTP is already enabled but still not allowing me to access switch to the graphical interface.
  • 4.  RE: HP Procurve Switch 2530 Can't open web interface
    Posted Jun 12, 2018 12:50 PM
    Thank you dhoenel
    It's Works for me on 2910al switch
  • 5.  RE: HP Procurve Switch 2530 Can't open web interface
    Posted Aug 21, 2017 08:48 PM
    Hi Dmitri,
    Check that you're using a supported web browser.  Generally speaking the switch web UI supports only the latest two versions of Chrome, Firefox, Safari (on MacOS), and IE.
    SVB
