Hello, I have to configure VLAN on a HP network to allow implementing VoIP and I need help please because I am not so used with the VLAN configuration.
The configuration is
A HP 4208 configured with 136 10/100/1000 copper ports and 8 1000BaseX Fiber at the center of the network. Connected by the fiber to the 4208 there are 5 HP 2510 family with 24 or 48 ports and 2 HP 2600 40 10/100 ports.
Now the only configured VLAN is the default.
Customer is not able at the moment to indicate on which ports the VoIP phones will be connected and is asking to configure all the ports as tagged. Furthermore the VoIP phones will be connected directly to the switch port where there is space or in between of the PC and the switch.
I thought to configure in this way :
Set a Vlan id 20 named "phones" on all the switches.
Set Vlan id 20 type voice
Set the IP for the vlans 1 (default) from 192.168.0.1 to 192.168.0.7 mask 23 bit
Set the IP for vlans 20 (where should pass voice data) from 10.10.10.1 to 10.10.10.7 mask 23 bit
All the port are untagged for Vlan 1 and tagged for vlan 20
Do you think this configuration is correct ? The traffic of the phones will be addressed through the vlan 20 ?
Thank very much .
P.S. This thread has been moved from Switches, Hubs, Modems (Legacy ITRC forum) to ProCurve / ProVision-Based . - HP Forum Moderator
#VoIP#VLAN
