Hello, I really appreciate your response and taking the time to respond to my message. Indeed, as you mention, I solved the problem by creating a VLAN and adding it to the interface. I very much appreciate the support provided. greetings
Original Message:
Sent: Jan 03, 2024 04:44 PM
Subject: HP Switch 5406Rzl2 interface configuration
Hi! what you're looking for it is not supported (setting an interface as a "routed interface"), you can instead set the VLAN membership of an interface in a way it behaves like a routed interface (Enabling IP Routing + setting a Transport VLAN + configuring a VLAN tagged membership, as example).
Original Message:
Sent: 1/3/2024 3:26:00 PM
Hello everyone, I hope you are well. Could you help me with the following, I have an HP 5406Rzl2 Switch, I am trying to configure an interface with a static IP in this case it is port B3, but it does not allow me to add the ip address 172.18.1 command. x 255.255.255.0 It has Aruba OS version KB.16.07.0003, could you help me on how to do it on this device?
I have also seen that the switch does not support layer 3 on its interfaces. Could this be the problem?
greetings
