HP TACACS+ with ClearPass
  • 1.  HP TACACS+ with ClearPass
    Posted Apr 29, 2015 04:30 PM
    I'm setting up TACACS+ with HP ProCurve switches and it's working just fine, however, we are looking for a way to send the privilege level and bypass having to enter an emable password?
    We are able to send the privilidge level, no problem. I've been unable to find a way to send a command back or a way to perform the enable Bypass.
    Thank you for your help
    Andy Clelland
    Structured Communication Systems, Inc.
  • 2.  RE: HP TACACS+ with ClearPass
    Posted Apr 29, 2015 04:32 PM
    Do you have "shell priv-lvl 15"?
  • 3.  RE: HP TACACS+ with ClearPass
    Posted Apr 29, 2015 05:14 PM
    I do, however the enable password is still required. There is a Manager user configured but if we remove that, you still have to type in enable to get to the enable mode. We are looking to pass that on and if you are given privilege level 15, just go directly into enable mode
    Andy Clelland
    ACMP, ACCP
  • 4.  RE: HP TACACS+ with ClearPass
    Posted Apr 29, 2015 05:20 PM
    Can you post your HP tacacs config?
    Tim
  • 5.  RE: HP TACACS+ with ClearPass
    Posted May 01, 2015 01:50 PM
    I'll post the config a little later today.
    I may have found what I'm looking for. Has anyone tried this?
    Creating a Named List for the Enable Mode Authentication
    To create a named list for the enable mode, you must determine the authenti- cation methods you want to use and the order in which you want the authenti- cation methods applied. From the global configuration mode context, enter:
    Syntax: aaa authentication enable default {none | line | enable | [group <groupname> | radius | tacacs+]}
    Andy Clelland
    Structured Communications
