Wired Intelligent Edge
HP TOPTOOL and ARP CACHE
  • 1.  HP TOPTOOL and ARP CACHE
    Posted Feb 18, 2003 03:27 PM
    How is it possible to get the arp cache of a procurve 4000 to find a specific IP adddress matching a MAC address with HP TOPTOOLS ???
    #toptools
  • 2.  RE: HP TOPTOOL and ARP CACHE
    Posted Feb 18, 2003 04:41 PM
    I've never used Toptools but the manual says you can get IP and MAC info from the Node Port Table. Devices/Device Types/Networking Types Then right click on Networking Types and selecting Node Port Table.
    See Page 6-7 in the TopTools User manual
    http://www.hp.com/rnd/support/manuals/toptools_hubs_switches.htm
    Ron
  • 3.  RE: HP TOPTOOL and ARP CACHE
    Posted Feb 18, 2003 04:54 PM
    Thx for your answer but it's ok for us only vhen a port is connected to another HP Procurve but it's bad when the port is connected to an end node workstation.
    Maybe it's because of our config.
    Thanks again.
    Jean-Luc Largeau
  • 4.  RE: HP TOPTOOL and ARP CACHE
    Posted Feb 19, 2003 09:58 AM
    Sounds like you do not have Discovery turned on. See Chapter 4 on Discovery. You may have to tell it about the subnetworks but it sounds like it should find all of the hosts on your network. It may take a while. Make sure you have Ping Discovery checked. (Fig 4-3)
    Ron
  • 5.  RE: HP TOPTOOL and ARP CACHE
    Posted Feb 19, 2003 10:13 AM
    It's ok now !
