maybe someone can help me with this error (or my configuration). This is my VLAN configuration on my Switch at the moment:
ID1 (default)
ID101 data 192.168.1.x
ID102 phone 192.168.2.x
ID103 quest-wlan 192.168.3.x
ID104 byod-wlan 192.168.4.x
I do have a DHCP-Server in VLAN101 with 4 Scopes for the 4 different Subnets. The Switch is working as the DHCP Relay and everything was fine so far. Because I wanted to prevent the switch to route between the Subnets (only DHCP-relay) I tried to manage this with ACLs (which is sort of a pain on this switch ...). But, after creating 1 ACL+Classifier+.... and assigning it to only one port for testing purposes (which worked) the switch cant assign the rule to more ports (Not Enough Hardware Resource ...).
Maybe a misconfiguration on my side? Thanks in advance!
This is the configuration file:
version 5.20.99, Release 1114
sysname HP_1920GPoE_Switch
clock timezone Amsterdam add 01:00:00
dhcp relay server-group 1 ip 192.168.1.11
domain default enable system
ipv6
loopback-detection enable
password-recovery enable
time-range Forever from 00:00 1/1/1970 to 24:00 12/31/2100
acl number 3000
rule 0 deny ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255 time-range Forever
rule 5 deny ip source 192.168.2.0 0.0.0.255 destination 192.168.3.0 0.0.0.255 time-range Forever
rule 10 deny ip source 192.168.2.0 0.0.0.255 destination 192.168.4.0 0.0.0.255 time-range Forever
vlan 1
description default
vlan 101
description data
vlan 102
description phone
vlan 103
description guest-wlan
vlan 104
description byod-wlan
vlan 105
description wantransit
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
traffic classifier IP102 operator and
if-match customer-vlan-id 102
if-match acl 3000
traffic behavior Deny
filter deny
qos policy IP102
classifier IP102 behavior Deny
user-group system
group-attribute allow-guest
local-user admin
password cipher XXXX
authorization-attribute level 3
authorization-attribute vlan 1
service-type telnet terminal
service-type web
stp mode rstp
stp enable
interface Bridge-Aggregation1
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 101
interface Bridge-Aggregation2
interface Bridge-Aggregation3
port access vlan 101
link-aggregation mode dynamic
dhcp-snooping trust
dhcp-snooping information enable
interface NULL0
interface Vlan-interface1
ip address 192.168.100.11 255.255.255.0
interface Vlan-interface101
ip address 192.168.1.1 255.255.255.0
dhcp select relay
dhcp relay server-select 1
interface Vlan-interface102
ip address 192.168.2.1 255.255.255.0
dhcp select relay
interface Vlan-interface103
ip address 192.168.3.1 255.255.255.0
dhcp select relay
interface Vlan-interface104
ip address 192.168.4.1 255.255.255.0
dhcp select relay
interface Vlan-interface105
ip address 192.168.5.11 255.255.255.0
dhcp select relay
interface GigabitEthernet1/0/1
port auto-power-down
stp edged-port enable
port link-aggregation group 1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
port link-aggregation group 2
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
port access vlan 105
interface GigabitEthernet1/0/6
port link-type hybrid
undo port hybrid vlan 1
port hybrid vlan 101 103 to 104 tagged
port hybrid pvid vlan 101
poe enable
interface GigabitEthernet1/0/7
port access vlan 102
interface GigabitEthernet1/0/8
poe enable
interface GigabitEthernet1/0/9
poe enable
interface GigabitEthernet1/0/10
poe enable
interface GigabitEthernet1/0/11
poe enable
interface GigabitEthernet1/0/12
poe enable
interface GigabitEthernet1/0/13
poe enable
interface GigabitEthernet1/0/14
poe enable
interface GigabitEthernet1/0/15
poe enable
interface GigabitEthernet1/0/16
poe enable
interface GigabitEthernet1/0/17
poe enable
qos apply policy IP102 inbound
qos apply policy IP102 outbound
interface GigabitEthernet1/0/18
poe enable
interface GigabitEthernet1/0/19
poe enable
interface GigabitEthernet1/0/20
poe enable
interface GigabitEthernet1/0/21
port link-aggregation group 3
dhcp-snooping trust
interface GigabitEthernet1/0/22
dhcp-snooping trust
interface GigabitEthernet1/0/23
poe enable
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
ip route-static 0.0.0.0 0.0.0.0 192.168.5.1 preference 10
snmp-agent
snmp-agent local-engineid 383030303633413236353133424345414641324431434531
snmp-agent sys-info contact Matthias
snmp-agent sys-info location OG
snmp-agent sys-info version v3
dhcp enable
ntp-service unicast-server 216.239.35.0
ntp-service unicast-server 216.239.35.4
load xml-configuration
user-interface aux 0
authentication-mode scheme
user-interface vty 0 15
return
#QOS#error#HP1920#vlanrouting
