Comware
HP5130ei password and password recovery not working
  • 1.  HP5130ei password and password recovery not working
    Posted Feb 29, 2024 01:12 PM
    Hi guys,
    Little question about  hp5130ei switches (stack of 3) which I recuperated to incorporate in a new network.
    Via the bootrom I started the switch without config, after startup 'dis cur' gave me 3 lines so no old config.
    Copy pasted the new config with, concerning authentication, the following :
     password-recovery enable
    local-user admin class manage
     password simple info
     service-type telnet http https ssh terminal
     authorization-attribute user-role network-admin
     authorization-attribute user-role network-operator
    (info = temporary pass)
    The first time I needed to login I got AAA authentication failure which is strange since I am 100% sure it is the correct password.
    Since pass recovery is enabled I restarted with ctrl+b and chose option 'Ctrl+P: Change authentication for console login, Skip console login authentication at the next startup. Yes Then option 0 reboot.
    Instead of getting into the config I get prompted to give credentials.
    So pass does not work and pass recovery neither -> ?
    I have other hp5130's on which I tested (and documented) this procedure and on these it went well.
    Tried chatgpt and it gave me a remark that this procedure might not work after certain firmware updates.
    The firmware on the switch was about 3 years old so I updated to : 5130EI-CMW710-R3507P18-US
    I think I am overlooking something, anybody any idea?
    Thx in advance.
