So I have a 5406Rz12 switch running latest firmware and I'm trying to connect it via 10G direct attach cables to my Aruba 7210.
(they don't work which is why i'm posting this)
The cable that I have is SFP+ Driect Attach 1m J92818. Even though this cable appears to be working because you get green link lights etc. it definately DOES NOT WORK.
I know my config is right because if I plug in a couple sfp's and put in a fiber jumper everything comes up just fine.
So my question for the day is........ What is the correct cable to get direct attach from my HP5406 to Aruba 7210?
Thanks !!!
