As the title states we need to implement dt-lacp for our vsphere servers, iscsi will be in use to our msa2040 san as well so jumbo frames all around.
So far this is all straight forward.
The kicker here is we also want to implement a switch pair to function as the routing for our core. we run a dual homed network with ipv4 and ipv6 routing. dt-lacp does not work with v6 so how would the links to the route pair support high availability? STP seems to be the only way? is there a more novel approach i'm missing?
#LACP#dt-lacp#ipv6routing#ISC
