last person joined: 10 hours ago
HP850 WLAN, use AP-group info?
  • 1.  HP850 WLAN, use AP-group info?
    MVP
    Posted Jul 12, 2016 07:02 AM
    So I'm setting up Clearpass for a company that just will be running their HP WLAN and Aruba WLAN side by side.
    Now I need to change the current user-only authentications into machine + user. Sofar no problem.
    But I also need to return different vlans depending on which AP-group the AP is in. For the Aruba WLAN I can just use the Aruba-AP-Group or even the Called-Station-Id.
    With the HP controller, I cannot seem to find anything that references this.
    So anybody has any idea on how to differentiate from which ap-group the authentiction originated? Or other ideas to get this resolved without having to manage a mac-list of all the APs?
  • 2.  RE: HP850 WLAN, use AP-group info?
    Posted Jul 12, 2016 11:40 AM
    Can you post a screen grab of the RADIUS request with all the VSAs?
  • 3.  RE: HP850 WLAN, use AP-group info?
    MVP
    Posted Jul 13, 2016 06:27 AM
    Managed to figure out a way to do it. Not the prettiest solution but at least it works.
    If I configure the service-template (~SSID profile) with a vlan:
    wlan ap-group algdi
     if-match ip 10.10.10.0 255.255.255.0
     ap ap-3.1
     ap ap-3.3
     ap ap-4.4
     dot11a service-template 1 vlan-id 123
     dot11a service-template 2 vlan-id 123
     dot11bg service-template 1 vlan-id 123
     dot11bg service-template 2 vlan-id 123
    then this vlan id is then sent along with the radius request as part of the NAS-port-id:
    Input RADIUS Attributes -
    Radius:IETF:Acct-Session-Id = 11607121154130ed09a5627f
    Radius:IETF:Called-Station-Id = 2C-41-38-DB-AA-8E:clearpasshp
    Radius:IETF:Calling-Station-Id = 28-B2-BD-42-D8-1C
    Radius:IETF:Chargeable-User-Identity =
    Radius:IETF:Framed-MTU = 768
    Radius:IETF:Framed-Protocol = 1
    Radius:IETF:NAS-Identifier = AC1
    Radius:IETF:NAS-IP-Address = 10.10.10.34
    Radius:IETF:NAS-Port = 16811984
    Radius:IETF:NAS-Port-Id = slot=1;subslot=0;port=8;vlanid=123
    Radius:IETF:NAS-Port-Type = 19
    Radius:IETF:Service-Type = 2
    Radius:IETF:User-Name = DOMAIN\\user
    That is the only way I found to get dynamic vlans that take the ap-group into acount.
    And for your reference Capali, these are all the radius VSA's that I receive in the request.
    EDIT: If you solve it like this, be sure to add ALL the vlans you may be pushing to users from this ap-group. The HP WLAN controller seems to send the previously pushed vlan when a user switches networks instead of the default vlan.
