Is it possible to configure VSF with the HP/Aruba 2930F 48G PoE+ SFP (JL262A) switches? Doesn't the VSF setup require at least one 10G fiber, 10G DAC, 10G copper (SR), or 40G DAC connection?
You can also configure VSF with 1G links. You only need to make sure that all port speeds across the VSF stack are the same.
Regards, Dobias
