Comware
  • 1.  HPE 1920-16G Switch JG923A PROXY ARP
    Posted Feb 22, 2017 11:23 AM
    Hi everybody.
    Just bought a 1920 16 port switch and been fiddling with it. On the brochures it says it has support for Proxy ARP feature but I'm unable to locate it. Anyone got ideas on how it works on this model?
    BR,
    -M-
    #L3
    #PROXYARP
    #ARP
  • 2.  RE: HPE 1920-16G Switch JG923A PROXY ARP
    Posted Feb 22, 2017 04:25 PM
    Are you referring to this statement on HPE OfficeConnect 1920 Switch Series QuickSpecs' Layer 3 services description?
    Layer 3 services
    • Address Resolution Protocol (ARP) determines the MAC address of another IP host in the same subnet; supports static ARPs; gratuitous ARP allows detection of duplicate IP addresses; proxy ARP allows normal ARP operation between subnets or when subnets are separated by a Layer 2 network
    • DHCP relay simplifies management of DHCP addresses in networks with multiple subnets
    On the web management interface I wasn't able to find anything related to Proxy ARP...so it could be a sort of typo (if you look at HPE OfficeConnect 1950 Switch Series QuickSpecs...the statement above is exactly the same but then the Switch's web management interface has a ARP Menu with ARP Proxy configuration...at least reading what is reported on the switch user guide about "Common proxy ARP and local proxy ARP" features).
    Would be interesting to verify if 1920's CLI (Comware 5.20) has proxy-arp and display proxy-arp commands with respect to what can be found on 1950's CLI (Comware 7.10).
  • 3.  RE: HPE 1920-16G Switch JG923A PROXY ARP
    Posted Feb 23, 2017 10:40 AM
    Yes, that is what I am referring to. I will take a look at the CLI once I have the chance. Will report back.
    EDIT: CLI is new to me. On which level should I run these?
    BR,
    -M-
  • 4.  RE: HPE 1920-16G Switch JG923A PROXY ARP
    Posted Feb 24, 2017 12:38 PM
  • 5.  RE: HPE 1920-16G Switch JG923A PROXY ARP
    Posted Feb 24, 2017 01:08 PM
    Yeah, I concur. Maybe an HP rep could comment on this? I read the marketing material as it should be there.
    EDIT: typo
  • 6.  RE: HPE 1920-16G Switch JG923A PROXY ARP
    Posted Feb 24, 2017 04:24 PM
    AFAIK on a HPE OfficeConnect 1920 - R1112 software release - CLI (system-view) session only arp related commands (arp and display arp) listed below are available:
    [HPE1920]arp ?
      anti-attack  Specify ARP anti-attack function
      check        Specify ARP item check status
      detection    Specify ARP detection function
      static       Static ARP entry
      timer        Specify ARP timer
    and:
    [HPE1920]display arp ?
      X.X.X.X      Display ARP entry by special IP address
      all          Display static&dynamic ARP entry
      anti-attack  Display ARP anti-attack information
      count        ARP Entries count
      detection    Display ARP detection information
      dynamic      Display dynamic ARP entry
      interface    Display by Interface
      slot         Specify the slot Number
      static       Display static ARP entry
      timer        Display ARP timer
      vlan         Display by VLAN
      |            Output modifiers
      <cr>
    There is no presence of any proxy-arp related command (like proxy-arp and display proxy-arp).
