Comware
  • 1.  HPE 1920s-24 Firmware 2.06 bug
    Posted Oct 08, 2018 05:07 AM
    Hi everyone!
    It looks like I found a bug in new firmware for the switch JL381A.
    When I enable https admin mode and disable http, I`m loosing management connect to the switch. Probably the problem depends to the cookie "secure" attribute.
    Please take a look.
    Firmware PD.02.06.stk
    Thanks in advance!
    PS certificate self-signed.
    The cookies:
    Set-Cookie: RID=***replaced***; Path=/; HttpOnly; max-age=30
    are missing the "secure" attribute.
    #bug
    #2.06
    #1920S
  • 2.  RE: HPE 1920s-24 Firmware 2.06 bug
    Posted Oct 09, 2018 11:00 PM
    can let us know the steps followed by you along with a screenshots
  • 3.  RE: HPE 1920s-24 Firmware 2.06 bug
    Posted Oct 11, 2018 06:51 AM
    Hi!
    Yes, sure.
    1) Enable HTTPS
    https://drive.google.com/file/d/1ovvXCvm5Z124wdLHnmmqSvr-j_jRMPft
    2) Disable HTTP
    https://drive.google.com/open?id=1y66piHp6W8JDJVzgUhZqwJnd2j5e71d9
    3) The webface is innaccessible via https = lost the management.
    https://drive.google.com/open?id=18E9O87IddjcKfsh1RaaxNYKm8DRUYx8q
    Please write me back if it`s not clear.
    Regards
  • 4.  RE: HPE 1920s-24 Firmware 2.06 bug
    Posted Oct 16, 2018 06:51 AM
    I came here to report the same thing. On a fresh switch straight out of the box. Upgraded to 2.05. Everything works fine. Upgrade to 2.06 and HTTPS breaks as soon as you disable HTTP. Unfortunately, I have 5 switches at other branches that I can't configure now (although SNMP still works). I'm hoping someone will post a way to roll back to the backup firmware without wiping the config.
  • 5.  RE: HPE 1920s-24 Firmware 2.06 bug
    Posted Oct 18, 2018 03:43 AM
    Hi @network_king! :) what can you say? Do you succeed to reproduce this bug?
    BTW I`ve tried to update 1820-48g with same version of the firmware with http disabled in configuration and after update I`ve lost the management to the switch, so I had to do factory reset.... When the version 2.07 will be released?
    Regards
  • 6.  RE: HPE 1920s-24 Firmware 2.06 bug
    Posted Oct 25, 2018 05:18 AM
    up
  • 7.  RE: HPE 1920s-24 Firmware 2.06 bug
    Posted Nov 19, 2018 05:58 AM
    up
  • 8.  RE: HPE 1920s-24 Firmware 2.06 bug
    Posted Feb 27, 2019 07:02 AM
    UP
  • 9.  RE: HPE 1920s-24 Firmware 2.06 bug
    Posted Feb 27, 2019 07:30 AM
    It looks like PD.02.08 was released in December. I believe I've verified that it works, but I haven't had time to update our production switches yet. I don't know why it doesn't show on the office connect page (http://h17007.www1.hpe.com/OfficeConnect/?SKU=JL385A) but I was able to find it by doing a search by product number (https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=JL385A).
  • 10.  RE: HPE 1920s-24 Firmware 2.06 bug
    Posted May 10, 2019 01:34 PM
    I have run into this problem upgrading from 1.08 to 2.06. I have tried the newest 2.08 and it is not fixing the issue. I have tried to go back to 2.05 and still having the issue. If I switch to secondary backup image with 1.08 I am fine. Any additional info on this. Right now I cannot get any 2.xx version to work on https...
