Comware
  • 1.  HPE 1920s with Cisco WAP 581
    Posted Apr 08, 2020 07:20 AM
    I've got switch HPE 1920s and Cisco WAP 581. I've set up local network on VLAN 100 and Guest Network with VLAN 200. On the HPE Switch when i set VLAN 200 include and tagging guest network work.(Ports 1-5) When i'm setting vlan 200 to the port where Access Points are connected too (Link Aggregation) i don't have access to internet.(Ports 25-29) Do someone how to resolve that issue?
    #HP
    #switch
    #cisco
  • 2.  RE: HPE 1920s with Cisco WAP 581
    Posted Apr 09, 2020 03:36 PM
    Hi!
    @Vicebal wrote: When i'm setting vlan 200 to the port where Access Points are connected too (Link Aggregation) i don't have access to internet.(Ports 25-29)
    I believe Links Aggregation (IEEE 802.3ad) can't (and should not) be used against the two Ethernet ports of your Cisco WAP581 Access Point: indeed one port works at 2.5 Gbps and the other works at 10/100/1000 Mbps. I don't see the way you could/should/would use any Link Aggregation feature involving those two ports (I mean the rule is either to use the 2.5 Gbps port or to use the standard 10/100/1000 Mbps port...not to aggregate them together).
